abbey road d enfer said:It's not skimping. It's just using modern parts that fit within the constraints of industrialized manufacturing.
Are people who use high-quality film caps skimping over using PIO?
How can you be sure that what you perceive as more "direct" is not an artificially "enhanced" transcription?
kingkorg said:I see nothing wrong with those capacitors there. It's C0G (NPO) capacitor.
Neve gear, and Neumann mics have tantalum capacitors in signal path, and people still use them.
VERY INTERESTED!gyraf said:I'll see if I can dig it up, but there was a late 1960'es AES paper on microphone sound that speculated if the signature sound of the u47 is really about the VF14s always being so microphonic. Which makes me smile every time the selfproclaimed microphone specialists over at GS talk about how important it is to find a tube with no microphonics
/JAkob E.
Nice links!Gus said:some links
http://www.thevalvepage.com/valvetek/microph/microph.htm
https://dalmura.com.au/static/Microphonics%20in%20valves.pdf
FWIW I installed a polystyrene cap instead of a capsule in a microphone the body and grill were installed and the cap worked as a low output level capsule. I could record sound
Others have posted about microphonic parts.
Jakob that sounds like an interesting paper.
kingkorg said:Well, the capsule in Manley Reference C is cheapest capsule available, found in Sterling Audio ST51 for example. So i wouldn't be surprised if they used 0.1$ cap instead of 0.2$ cap.
Icantthinkofaname said:It almost pains me to say that I prefer $100 and $200 mics.
You're an iconoclast! ;DWhoops said:The high prices don't necessarily reflect a better sound or performance, they reflect a brand, and hype or a specific market target.
abbey road d enfer said:You're an iconoclast! ;D
Whatchathink?Whoops said:;D ;D ;D ;D
Definitely,
Do you join me?
kingkorg said:It is the one found in st51, not sure, if could be 32, but i am sure it's not 35mm.
The only results from "VF-14" search on AES library is the Bauch 1953 and Schneider 2014 (#17212); "U47" search = Russ Hamm "Tubes vs transistors" plus the two previously mentioned; Josephson #2983 may be of interest; "vacuum tube microphincs" nothing.gyraf said:I'll see if I can dig it up, but there was a late 1960'es AES paper on microphone sound that speculated if the signature sound of the u47 is really about the VF14s always being so microphonic. Which makes me smile every time the selfproclaimed microphone specialists over at GS talk about how important it is to find a tube with no microphonics
/JAkob E.
