Me too, but when they have a tool missing from their toolbox it's not so great.
Ouch
Probably, but they are nothing like as bad as people suggest.
Very often they are far better in tweeter sections than some brands of film capacitors.
You mention "rolling" capacitors... I will happily roll in Alcaps over cheap film.
There's often much more detail, and more body to the sound - which is the perfect combination. In another thread (either here or on the Naim forum) someone replied to me on the subject mentioning that he'd had his Kan Mk1s redone with Solen caps (which I would have expected to work) and it killed the music for him.
Somewhere I have a jpg of some impedance measurements from a decade or so ago of an Alcap vs MKP10 vs a Rubicon ZA and, IIRC, the Alcap is the one that looks most like a theoretical capacitor.
I agree. I would go so far as to say they are better in some power positions too.
If you have an RC on your rail, I would use a bipolar there too.
I think Meridian are hip to this too. I saw a part photo of one of their internal amplifiers and it had axial caps in the familiar Alcap blue, right next to the output transistors. There wasn't enough of the circuit board shown to be completely sure of what they were doing but I suspect they were between the rails and ground
Not untrue. I seem to remember this is in Ott and meant to find it for you but was behind in replying here already. I certainly remember my reaction at the time was "Oh, for God's sake! Really?". But of course there are currents in the casework.
It's a very good reason to keep the transformers outside the amplifier part.
This is interesting. Maybe those orange drop caps really are the reason only Nakamichi managed to make decent cassette decks. Such an overlooked medium!
I think you've misconstrued my position on things audiophile. I would defend almost everything that's usually dismissed as "audiophoolery". In fact I am militantly against anyone who believes that SINAD encapsulates the performance of any piece of equipment (while also not being pro injecting euphony).
I'd say PP is pretty well damped by comparison to PE, which is why it was used after bextrene in loudspeakers. Sure, it is usually loaded with carbon black in loudspeakers, which helps too, but that was mainly for UV blocking (which it has done amazingly well if you look at a B110 SP1228, 30 odd years on). It's also used in composites for toughness and damping. It is 1/3 as stiff as PET and you can test its properties yourself on any milk container. Or see here: Plastic Rigidity & Material Stiffness, Units, Formula & Table
FKPs and MKPs are my go-to capacitors. I usually stick to MKP4s as MKP10s can get a little expensive. I thought MKPs were wound. Not sure about FKP but I love them.
I'm not actually pro DC coupling these days but I would be very interested in how you think a servo ought to be done.
I was very taken with how Bruno Putzeys did the input of a preamp by subtracting a low pass from the signal.
I was thinking more a 70mm long capacitor with a 50mm diameter, rated at 600V, which is the kind of thing that sometimes appears at the input of "exotic" MC phono preamps.![]()
I don't think anybody denies the fact that loudspeaker cables interact with the amp and speaker. However, in most cases, the differences are way outside the domain of perception.
Even the DCR of the cable is not such a significant factor,
I used to write a magazine column called "audio mythology" back in the 80s (40 years ago).
Some old myths refuse to die.
What kind of "degradation"? Something that alters the chemical composition of copper in a way that makes it non-linear?Interconnect cables are a potential source of distortion. For a long time I used chin ese starquad cable for my AP2 connections. after a few month the softeners in the PVC insulation had degraded the conductors sufficiently to cause observable increases in measurable distortion.
That supposes zero CMRR. Playing with unbalanced connections is a receipe for headaches.Ground resistance in interconnects?
Allowed current leakage in Class II it is <= 0.25mA, now 0.25mA * 1 Ohm = 0.25mV which with a 2V line signal is 78dB SNR).
Subjective listening tests? Not double blind?
Interesting fact with those underhung coils you mentioned.The main reason was loudspeakers were designed for efficiency. If bass was needed, a large speaker was used.
The use of an "underhung" voice-coil, where all the voice-coil is in the magnet's magnetic field results in permanent motional control of the voice-coil movement, but also limited excursion.
Modern speakers use "overhung" voice-coils, which results in only a fraction of the voice-coil being under motional control. This provides better linearity at large excursions, at the cost of impairing low-level efficiency.
The actual control the amp has on the speaker, as suggested by damping factor, is almost irrelevant since the output impedance of amps have usually been much smaller than the DC resistance of the voice-coil. Some designers have conducted tests with varying degrees of damping, from no damping (current-drive) to negative-impedance, as JR reminded.
In particular, current drive has its followers, but implies the use of specifically designed transducers; it works well for midrange, not so well for bass.
Doesn’t that depend on the actual test? Difference is just one goal of listening tests. I could imagine tests (e.g. using a semantic differential) where the goal is to find out what sounds best. For statements that can be generalized to some degree (in contrast to subjective listening), the effort is quite high (as already mentioned).
There are cases where it's not possible. For example the parametric EQ section in a mixer. High-value pots are not desirable for noise reasons.
Using servos, not only at the ins and outs, but at the potentiometer nodes is unconceivable.
The only practical solution is to use electrolytic caps.
Until only recently FET input opamps were too noisy for this application.
On the other side, we strive for greatest power transmission from amp to speaker, thats why tube amps should have the same output impedance as speakers.
Sorry, my english is bad. Max. power output can be transmitted if the load equals the source impedance. It's one of the basic theory rules.Do we strive for that ? Aren't we more interested in efficiency (not burning off energy in our amplifier) ?
Equal source/input impedance is an archaic (old) strategy for audio interfaces. Instead of maximum power transfer, modern interfaces use "bridging" interfaces to maximize voltage transfer. Bridging input impedance is typically 10x source impedance so inputs don't excessively load down signals. Lots of older legacy gear standardized on 600 ohm source and input impedance for maximum power transfer. Modern gear using bridging interfaces use much lower source impedance and much higher input impedance.Sorry, my english is bad. Max. power output can be transmitted if the load equals the source impedance. It's one of the basic theory rules.
Vacuum tubes have high source impedance compared to typical loudspeaker loads. Output transformers step down the output voltage to better match speaker impedances. Transformer impedance changes with the voltage ratio squared.We strive for max. power when designing a working point for output tubes of power amps, too. If the speaker is highly efficient, we need lower power output from the amp, that's favorable of course. To design a monster amp for a low efficiency speaker is what's been done for quite a while. Surely not the best solution but everybody does to achieve good "speaker control".
BTW, generations of vinyl listeners have lived with much less S/N.
This is seldom the case, particularly with pentodes.Interesting fact with those underhung coils you mentioned.
I read rules about those damping factors to control a speaker best. On the other side, we strive for greatest power transmission from amp to speaker, thats why tube amps should have the same output impedance as speakers.
That's the idea.I think it has something to do with the output circuit, mine is including negative feedback. It makes the speaker sounding more controlled and damped.
I'm not talking about teh capacitors used in filters, I'm talking about the caps that are necessary to prevent DC in the pots. People don't want to hear ugly scratches when they select frequency or change gain.Well, the values of capacitors needed are commonly available in Film.
Not a reasonable choice when you want 4 parametric sections in a mixer channel. Each section having 4 or 5 opamps.Well, again, I posted elsewhere my "AC only" Op-Amp transposition of a standard OPA. Noise levels are low. They would perfectly.
Yet SSL, Neve et al didn't do it; not even Studer or Focusrite.That makes a very low noise FET input OP-Amp and they used to be quite cheap.
You're totally neglecting the industrial aspects, where cost optimization is a vital factor.So, sorry, on evidence I must reject all your arguments as not valid except in a "we try do this the cheapest way that will kinda work" way. In which case performance compromises are routine and not an issue.
It's often an argument between pro audio and HiFi. If a recording mixer was made using the same methods and principles that pertain to HiFi, it would cost several $M.It is easy to do cheap no-fi. What place that has in mixing consoles for live performance or recording is another question.
At moderate levels, yes. When the voice-coil starts to reach the point where induction decreases, distortion increases, and there's no counter-effect from the back emf.Current drive works great for bass.
Resulting in loss of efficiency.It is just that the highly nonlinear damping of the Amplifier attempting to short-circuit the back-emf (aka dumping fuctor) needs to be replaced by mechanical (and usually highly linear) means.
I don't see how a piece of Al can result in strong damping. Maybe I lack vision...One could, for example, make a single piece, non-slotted aluminum voice coil carrier of the correct thickness, to give our driver a Qm that is equal to desired Qt, with current drive We will approach infinity, so Qt ~ Qm.
There is a commercial example of a loudspeaker using small speakers with extreme mechanical damping. It takes 1.7kW on the bass section to provide decent spl.Seas had a few drivers with a low Qm (~ 1.3 IIRC) which when used with current drive on open baffle of the right size produced spectacular results.
Motional FB is just another way of applying electrical damping.Applying motional feedback is another option.
