Where did I say, or even suggest, the products are designed by ear?
ct. said:
As an example, I will be impressed if you can find me a single audio company that regularly uses double blind listening tests to assess its products. There are plenty of companies that have tried, but admitted they either uncovered them or gave up on them because is was unfruitful. You need people who know what they are listening for and who have good ears. That comes by exposure and through experience and they are few and far between.
Expert ears?
Back in the 70s/80s designing studio effects (Loft delay/flanger) it was pretty much a wholly design by ear exercise. Since then my focus is on clean linear audio paths. I let the bench test numbers tell the story.
But one would hope that every company listens to its products before releasing them onto the market, so as to assess whether the design process has met its hopes and expectations. The minimum for this would be that it is at least better than the product it's replacing and hopefully better than its competitors.
I have written about this right here for years (decades). My last day job at major manufacturer we had QA people in the factory performing crude listening tests right on the production lines. Humans can be pretty good at finding deviation from normal in that environment. QA people discovered a noise problem from a newly approved capacitor vendor. Engineering had already approved the new capacitor but production QA discovers a noise issue. I never got to the bottom of the "problem", I just black-balled the new vendor and switched back to quiet capacitors. ( I suspect the new caps were not properly formed in, but didn't waste any more of my time on them).
I have long opined that listing tests serve a function to confirm that we have actually measured the correct factors. I determined decades ago that I can measure stuff that I cannot hear, but so far I have always been able to measure things that I can hear. So listening tests play a role backing up bench testing.
Do you know of ANY company that uses double blind testing to make this assessment and relies solely on its results? I don't even know one that would use it at all.
No... I have used plenty of single blind tests, not perfectly controlled, almost as much to capture a group sentiment for subjective sounding circuits like clip limiters (DDT) and the like. Results were not always the expected or desired. For example the unsophisticated listeners often preferred the sound of amplifiers allowed to clip (most likely they preferred the somewhat louder, higher power output).
You are a Moderator and representative of this website. Correct?
I am an unpaid volunteer moderator. My personal opinions are mine alone.
I have seen some of your moderating and the less said about that, the better. Are veiled insults part of the required moderating skills here? So far, I'm in need of a dislike button, am a liar, and am now an audiophool. This is not looking promising. I'm not fussed by the audiophool accusation and am usually happy to defend it, but coming from a moderator is different.
I have a very long history dealing with the esoteric audio community, try not to take it personally I am not trying to insult you, but making perhaps a knee-jerk response. FWIW "jerk" is part of knee-jerk, mea culpa.
While I remember, scientific "truth" does not have a statistical component.
that actually sounds true.
Truth is more of a philosophical construct. But I am not a philosopher so will stop now.
Something does not become more likely to be true the more tests it passes. Karl Popper covers this at some considerable length in Conjectures and Refutations. Nor is science a consensus endeavour.
Not to change the subject but modern climate
science appears to be very much a "consensus endeavor".
Sorry about the veer... my personal opinion again.
