So much about perceived sound quality is subjective. There were (and still are) plenty of people who think that an SSL console driven into the red is "the sound of rock".
Well, they are wrong, the sound of Rock is an old Neve console driven into the reds...
Sound City (2013) | WatchDocumentaries.com
So many of the greatest rock recordings want through that desk, it's not funny.
People today use all kinds of distortion plugins to chase the technical imperfections of yesterday's gear.
Or they chase the original sound thinking utterly wrongly that it were those imperfections that madd the sound.
Every time I hear these software emulators, even the "VCM" modules in my yammie, I cannot but go: "What hilarious dummy sound".
For my own ears, the circuitry in my console, consisting of nothing better than well-implemented (that's crucial) RC4558 and NE5532/4 is good enough to run everything through. Plenty of coupling caps (with small film bypasses) in the signal path, that make no audible difference vs. what is coming straight out of my DC coupled discrete DAC.
Good job. Or bad DAC... Hehehe... No offense meant.
Still I cannot help wondering what it would be like if you changed the 4558 & 5532 in a few channels for OPA1678 and tries an OPA828 where'd you use 5534...
Back in the day when I still did that, I offered to repair/mod one damaged channel for a low cost, as taster. Then I used OPA627/637 and OPA2604 with adapters for the 074 replacements.
I cannot recall a case where I was not asked back to mod the subgroups and sum and at least a few channels. I especially wrought my revenge on desks designed by one DS where one also had to fix the grounding.
I think digital audio is a far bigger problem, especially the converters availible today that often achieve great THD, noise and frequency response specs but still somehow manage to sound really artificial.
I agree. One time in a massive queue at Beijing immigration (before the Olympics , a lot of rules suddenly changed and every foreigner had to get his paperwork resorted), I met an ABC (nominally American Born Chinese, usually also applied to US based and educated CBC's) who's job was head of the ADC/DAC chip development division for a famous US based maker, who's chip Ard one of the staples in pro audio.
We started chatting and found we worked in a similar field. In the end we went out for dinner at Yin Yong Restaurant for Duck, Cat Ears and Bear Paw.
And he came over to have a listen to the audio system we were making, which he thought sounded great.
We also talked about if he ever listened to the ADC/DAC Chips his people designed.
He looked at me quite like "is he mad" so I went and pulled out the EVM for the latest greatest chip out and plugged it in and set up level matching in the Amp ( < 0.5dB difference).
We played the same cut synchronised and switched between the two and his face fell. The EVM sounded, politely put, English way, "pretty good" (that's English for terrible).
He was even more shocked when I explained to him what DAC Chip my design used. We went to the famous mushroom hotpot after and talked a lot of shop, on what I thought were reasons for the difference is in sound.
There is a corollary here, quite a few years later this chip manufacturer introduced a fundamentally new range of DAC Chip's. And tarnation and blimey, they sound excellent. I actually designed them into several products. I also checked on the guy, he is still there.
I suspect, he started to listen, in more way than one.
And don't get me started about ITB processing with lot's of stages of real time up- and downsampling, that sonic signature is all over modern music and it's far worse than an 80s Rick Astley record to my ears.
True. Mind you, it DOESN'T have to be like that, that's all down to the wet ware, not the software.
In principle nothing wrong staying in the box, but it is tempting to overegg that pudding.
Thor
