ilfungo
Re: D-AOC PCBs - the building and help Thread
« Reply #780 on: May 04, 2010, 05:30:26 AM »
II saw that many have mounted with the heatsink off the card ....
is to prevent overheating?
[silent:arts]
« Reply #781 on: May 04, 2010, 06:05:32 AM »
yes. mount it (important: insulated !!!) to the case is much better than the heatsink on the PCB.
ilfungo
« Reply #782 on: May 04, 2010, 06:56:00 AM »
Thanks silent:arts
What do you mean by " insulated"?
[silent:arts]
« Reply #783 on: May 04, 2010, 07:03:23 AM »
no electrical contact between the TO220 and the case.
http://www.aosmd.com/pdfs/appNotes/AN101_TO220_Guidelines.pdf
Benny
« Reply #784 on: May 05, 2010, 03:31:41 PM »
Hey guys,
did some improvements on my D-AOC yesterday. Kubi mod etc.  The unit sounded great but I did not calibrate the meters yet. So I installed a 100k trimmer for R126 and R226 and followed the instuction posted earlier in this thread. Channel 2 is now working great. Meter tracking is a little off, but no problem for me.
But I couldn't get the first channel working right. Everytime I turn up the threshold pot the VU goes up, too. So I checked everything and found out that suddenly the NE2 lamp in ch 1 did not work. I thought that it could have something to do with the meter tracking, took out the board, soldered in a new NE2 and after powering up channel 1 did not compress any more. In and out amps are o.k. and sound great but no compression.
Checking the unit again I found out that the stereo-link wire from channel 1 got torn off the switch while soldering and maybe got contact to the power switch, which is right below the link switch in the purusha case... ;D I soldered the wire to the switch and tested again, but still no compression...
Any ideas??? Checking the pcb for a day and a half, my brain's empty now.
Benjamin
wolfgang
« Reply #785 on: May 05, 2010, 04:56:18 PM »
Maybe the vactrol got damaged? I dont know how to test it properly but you could compare it with the working channel?
regards,
Wolfgang
Benny
« Reply #786 on: May 06, 2010, 01:13:13 AM »
I just put two new vactrols in my D-AOC, calibrated the meters again and voila...
My D-AOC works perfectly now and most of all sounds great!!!  ;D
I just tested it a bit on vocals and love it.
Meters tracking is good, btw.
Benjamin
« Last Edit: May 07, 2010, 09:34:48 AM by Benny »
Soeren_DK
« Reply #787 on: May 11, 2010, 06:41:35 PM »
Anybody done some drawings of the off-board-wiring?
Soren
Quote from: idylldon
...it works like a champ and is as quiet as a mouse pissing on a cotton ball.
http://www.soundcloud.com/doctorsclub
jensenmann
« Reply #788 on: May 16, 2010, 05:01:44 PM »
After a DIY break of more than a year I finally made it to put the longtime finished PCB in a case. Here´s some pictures from my DAOC on the bench while meter calibration. I replaced R126/226 with a 100k trimmer to get a better GR tracking. Some of Kubis mods are installed. Sidechain filter frequency is 200-something Hz. Input iron is Stancor/MCI 4:1 reversed, output is Edcor WSM. Tubes are Siemens/Telefunken, meters are NOS Philips. Unfortunately I could not yet listen to it. There´s some 2W resistors which I have to replace because they get very hot and are placed too close to caps. They will damage the caps if running for a longer time. Wiring is a mess, of course.
Thanks to Analag, Volker, Kubi and Frank "NRGrecording" for making this happen.
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
[silent:arts]
« Reply #789 on: May 19, 2010, 09:23:15 AM »
Jens, you know we need more and larger pics  ;D ;D ;D
Soeren_DK
« Reply #791 on: May 19, 2010, 11:06:44 AM »
Soren
Soren
Eje2005
« Reply #792 on: May 19, 2010, 11:47:09 AM »
Soren
There´s not much to draw up.
What are you wondering about?
[silent:arts]
« Reply #793 on: May 24, 2010, 08:57:59 AM »
for jensenmann:
 ;D ;D ;D
Soeren_DK
« Reply #794 on: May 27, 2010, 04:29:15 PM »
Soren
I can't figure out how the stereo switch is working?
@Volker
Do you have the layout for the Haufe trafo pcb you have in your unit? I have some 255/1 I want to use..
Soren
« Last Edit: May 28, 2010, 06:14:43 PM by Soeren_DK »
Benny
« Reply #795 on: May 28, 2010, 07:50:18 AM »
Just connect the + pin of each channels stereo link pad.
Soeren_DK
« Reply #796 on: May 28, 2010, 06:24:31 PM »
Of course... hehe.. stupid question.
How does it work? What does the stereo signal do to both units? How do you control the stereo unit?
Can I use any Lundahl for this project?
I have some LL1540 and some LL5402 laying around..
Soren
seavote
« Reply #797 on: May 28, 2010, 06:59:57 PM »
not certain so if im wrong someone correct me.
i believe the sidechain signals are combined and then sent to the vactrol. this way both sides recieve the same signal and compress equally.
the two pin molex confused me.       (-) remains unused
Everyday is a gift. Thats why it's called the present
[silent:arts]
« Reply #798 on: May 29, 2010, 04:36:08 AM »
absolutely correct
there are no one pin molex available ;D
and I like to use shielded cables, and connected (-) to ground.
the controls of both sides influence the gain reduction in stereo mode.
Soeren_DK
« Reply #799 on: May 29, 2010, 04:43:25 AM »
Thanks :D :D
@Volker
Soren
Last post November 28, 2008, 04:25:43 AM
by [silent:arts]
Last post August 10, 2011, 10:10:47 PM
by JimiH
Last post December 10, 2009, 05:43:37 PM
by Junction
Last post August 13, 2018, 10:11:57 PM
by TDM
