gyraf
Official G7 microphone help thread
« on: February 13, 2014, 03:59:36 AM »
This is the Official G7 microphone help thread.
META - The G7 microphone - by Gyraf
http://www.groupdiy.com/index.php?topic=4952
Some already-covered topics include:
"Radio World" article featuring G7 mic
http://groupdiy.com/index.php?topic=53917.0
My very own Gyraf G7 build thread
http://groupdiy.com/index.php?topic=48665.0
My Gyraf G7 build thread
http://groupdiy.com/index.php?topic=48676.0
G7 with No Problems
http://groupdiy.com/index.php?topic=42416.0
G7 electrical "hum" problem
http://groupdiy.com/index.php?topic=49861.0
G7 noise troubleshooting session. [Solved]
http://groupdiy.com/index.php?topic=42136.0
Noisy G7
http://groupdiy.com/index.php?topic=41835.0
G7 PSU Help Needed
http://groupdiy.com/index.php?topic=1655.0
G7 resistor value question
http://groupdiy.com/index.php?topic=55228.0
G7 -- Question about polystyrene (styroflex) capacitors
http://groupdiy.com/index.php?topic=53540.0
my first G7
http://groupdiy.com/index.php?topic=54823.0
Gyraf G7 Capsule
http://groupdiy.com/index.php?topic=55109.0
Gyraf G7 polarisation voltage modifications for M7 type Capsules
http://groupdiy.com/index.php?topic=51320.0
G7 Mic Capsule voltage with a trimmer?
http://groupdiy.com/index.php?topic=54548.0
G7 Mic build - 33meg resistor - is 22M or 47meg OK ?
http://groupdiy.com/index.php?topic=51677.0
G7 pcb - fine traces at TX output - cut or not ?
http://groupdiy.com/index.php?topic=51887.0
G7 - advice on cleaning the board
http://groupdiy.com/index.php?topic=51267.0
Gyraf G7 body?
http://groupdiy.com/index.php?topic=49042.0
Valve Mic Cable for G7?
http://groupdiy.com/index.php?topic=1589.0
Jakob E.
« Last Edit: March 07, 2014, 12:40:50 AM by gyraf »
LG
Re: Official G7 microphone help thread
« Reply #1 on: March 02, 2014, 07:17:21 PM »
I'm the first one :)
mains:
237v ac
secondary of 220:9 transformer
10.77 v ac
powersupply problem. My reading are
primary of 220:15 tranny
162.9v ac
after rectifier (+160 side of the psu)) 208.5
at pin 2 189v dc
allso, the voltage at pin2 is not rock steady, goes down to 150 every now and then.
can anyone spot the problem? i guess i need higher value 1W resistor since I'm getting to high ac after 2nd tranny. But could there be something wrong with the rectifyer?
all the best, Leifur
gyraf
« Reply #2 on: March 03, 2014, 04:24:33 AM »
Hi Leifur,
Rectifier is fine, you just need a larger value resistor between your reservoir capacitors
Jakob E.
Dr_J
« Reply #3 on: March 06, 2014, 04:38:19 PM »
The topic fits not really the contend:
http://groupdiy.com/index.php?topic=19400.20
But at the end some helpful information on choosing psu transformer;
plus my experience :)
ROCK-ON!
museic
« Reply #4 on: March 09, 2014, 05:16:56 PM »
Trying to finish my power supply without having my mic finished yet so wondering if this is working. before hooking up my transformers to the board i paralleled the seconaries of each transformer and connected them together and was getting 12.8 vac between them. Then i ran the 2nd transformer primary in series and measured 140vac on it output.  After soldering these to the board i measure 6.6vac between the two 9v solder points and 28vac between the two 120v solder points. I also measured between ground and pin 2 and get 4.2 vdc. It also seems that the first transformer is getting pretty hot.
Any advise on what to look for?
Dr_J
« Reply #5 on: June 13, 2014, 04:21:09 PM »
Hi!
No help here needed  8)
Just my result.
Here is my one, first of beauty-full twins  :D
Here sister although now has been born  ;D
- Tims capsule
- AMI T47 transformer
- Voltage modification for Tims capsule inside the mic.
- Gotham cable
- Amphenol DIN connectors
The brass tube has a 2.5mm thickness!! witch leads to a weight of approximately 850g.
I wanted to do it the "old fashion Jakob way"  :D
Thanks Jakon for that project!!!
And if i look now around here, DIY-micing has done a big step forward since I started gathering info.
Took me about 2 years, beside some other projects of cause  ;D but it was real DIY - hard work and fun!
And no problems!
Some more sound tests have to be done, up to now everything looks fine.
ROCK-ON!
« Last Edit: June 13, 2014, 04:38:37 PM by Dr_J »
skeld
« Reply #6 on: July 15, 2014, 06:23:15 AM »
Hello I just finished my 3rd. G7 microphone and I am dealing with problems, other two microphones I have work perfectly. This one is the same design using TimĀ“s capsule CT12 same as the other two. The thing is that the signal I get is very weak and sometimes pops very high, also the sound is little weird and thin. I found out, that polarization does not match when I did some polarization testing of the mic. I checked the circuit several times and found nothing. I am starting to be hopeless.  :'( Have any of you guys clue, what shoud be wrong? THX for advise.
gyraf
« Reply #7 on: July 15, 2014, 09:53:53 AM »
Skeld,
Check your supply voltage first. The CT12 works it's best between 110 and 120V DC for the HT, measured with microphone connected, after heat-up.
Then check your variable polarisation voltage - should go from 0V (omni) to HT-voltage (fig-8)
Jakob E.
skeld
« Reply #8 on: July 16, 2014, 06:19:54 AM »
Thanks Jakob, I will check that again. I am testing the microphone on the same supply and same cable, where other two G7s work fine, I asume the catch is somewhere inside the mic body. I know that measuring right at the capsule is impossible, but do you think is worth measuring the voltages of each microphone right at capsule to see the just possible differences at least? I am a newbie in capsule world, but is there a possibility that capsule could be faulty?
Matador
« Reply #9 on: July 16, 2014, 05:03:16 PM »
Hey Jakob, I'm trying to modify a C12 supply to power a G7, and have a question about the current requirements for the EF86 tube.
Based on the G7 PSU schematic, a 10K filter resistor drops the rectified 180V DC to the final 160V DC B+ voltage, which implies a current of 2mA entering the B+ node:  0.8mA will go through the polarization resistor string (160V/200K), and 1.2mA will ostensibly be the current going out for the tube.
Does this sound right?  If I am taking a 280V rectified voltage down to 160V @ 2mA, I'll need to increase the total filter resistance from 10K up to 60K.
gyraf
« Reply #10 on: July 17, 2014, 02:50:35 AM »
Mat - that is correct, but remember it's an approximation, depends on the actual tube's gm. Try it, measure in-circuit, and adjust.
Jakob E.
« Reply #11 on: July 18, 2014, 11:45:16 PM »
Hello. Ok...I've built a couple of g7's. They sound great but I noticed they seem extra sensitive to p pop's. The audio cuts out at the slightest pop. one g7 has a Tim Campbell capsule, the other one has a Peluso 47 capsule. They both have the 60v polarization mod. Any ideas. I use a pop filter, but I have many other condenser microphones and these are much more sensitive to pops. Thanks for your time.
Trying to make great music!
gyraf
« Reply #12 on: July 19, 2014, 02:58:33 AM »
Yes, in general, real CK12's are very sensitive to pops - this is a byproduct of achieving the very-detailed sound in this type of capsule, so I consider it part of it's beauty.
Use with popfilter - simple as that.
If you need to use it handheld, special care must be taken (!!). Look up e.g. K.D.Lang's unplugged video for reference.
Jakob E.
« Reply #13 on: July 21, 2014, 07:41:26 PM »
Wow! Great Video!! What a voice and what a sound! Thanks for the response. I do love the sound of these microphones. I guess better microphone etiquette is warranted. Thanks
skeld
« Reply #14 on: August 05, 2014, 07:13:49 AM »
Hello, I checked everything again. Power supply measured with both of my microphones has the same voltages. I checked all the components, replaced tube with same results = weak signal and characteristics does not match. Finaly I opened the head basket and found CT12 front like this :-(. It is stuck in the middle to the backplate I guess. Do you have a clue what could cause this?Power supply is OK and all voltages measured inside mic body match the other microphone with CT12 and that works fine. I will probably have to contact Tim to solve this :-(.
« Reply #15 on: August 05, 2014, 11:15:50 AM »
What is your polarization voltage? (EDIT: measure before the 1G) "Stock" G7 circuit puts out too much for CT12, which takes 60V max. Too high voltage makes the diaphragm stuck to the backplate. No good, can cause damage. I think this is not documnted well enough in the build documents.
skeld
« Reply #16 on: August 05, 2014, 03:47:03 PM »
Aaaah  I have almost 80V and almost 160V in fig. 8, standard G7 design.  I did not take care about voltages, because my other two G7s with CT12 were ok with these and never had problem with them. So this could damaged the capsule?  :'( So the right voltages for CT12 are 60V for the backplate and polarization 0-60-120V?
« Reply #17 on: August 05, 2014, 11:23:05 PM »
Correct. Some units seem to work with a higher voltage, but thats probably not good for the capsule life.
gyraf
« Reply #18 on: August 06, 2014, 02:49:59 AM »
Yes, the collapsing of the membrane shown in the (actually very good!) picture is the result of too high polarisation voltage.
But no fear: I have not yet seen a single capsule that was permanently damaged by this - just get working voltage down to some 110-120V by changing the PSU dropping resistor.
Jakob E.
lkipod
« Reply #19 on: August 06, 2014, 03:49:09 AM »
Jakob E.
Hi Jakob,
Wouldn't changing the resistor in the PSU also change the plate voltage? Or doesn't it matter?
Sorry if this is a noob question.  ::)
Best Moshe
