Alexandru marian
- Joined
- Oct 13, 2014
- Messages
- 127
I doubt AC is called for anywhere. 250V is a more conservative rating. If you have the part and it fits, use it.
gyraf said:2x12V is too little for the GSSL
Murdock said:Hey Jakob,
I'm searching a suitable power transformer for my G7. I asked someone, and he said the PRR176 Transformer would work (https://www.don-audio.com/prr-176-power-trafo-sec-18v-18v-120v_1).
He said the LM317 could handle the 18v.
Can you confirm that this transformer will work with the G7?
You can connect both 18V in anti seriall and get 9V.
gyraf said:Note that you can only do this if it's a 18V center-tapped trafo (i.e. 2x9V)!
Jakob E.
Dumbascii said:Had an old (though unused) MXL V69 with a popcorn-ridden tube. Research showed it wasn't worth fixing, especially due to the soldered in submini tube. I used the Gyraff G7 schematic to hand build a new head amp and make some simple mods to the existing PS-69 power supply. Even with the giant V69 body it was a challenge to cram everything in there. I was shocked to find that it worked on the first try!
-frank
