Ok, It's been several more days, I've tried swapping everything I can think of and I still have the same issue.
All IC's have power, I swapped all IC's.
Here is what everything looks like with the pots at null..
I can of course move the dip or the peak, the dip is the low mid, and the peak is mid-hi, the q, changes the peak crest.
[/img]
I can not drop the mid-hi lower than it is wrong in gain, only to about where it should be for bypass and I can't boost low and higher the same way.
I had this working so I had a flat bypass line, but I have fowled it up somehow, I have pretty much changed everything more than one, the back of the boards looking pretty used at this point.
but I can't seem to solve the basic problem, and I'm not sure how I introduced it in the first place, because, it was working, all it did was move around in a box a little.
I have:
swapped with each other the 33u's.
swapped the 22p's
removed the pots, twice, moved them around.
replaced a switch.
swaped with each other, then replaced completely the 22n's on
7a and 8b.
swapped with each other, then replaced completely the 68n's on 9a and 10b
swapped some 100n's.
swapped the 47ufs with each other.
freq is flat at 20k leading into 8a.
6k8 contains offending frequency. at volume (think it was by itself.)
removing 10k from bal - still seems to be the proper volume level between
bypasses relitivily.
Hopefully I can build anotherone right off the bat and be back to where I was, but, then if I break it again, I'm at a loss, there a few differences, in the rev's, but I figured I would have stubled on it by now and I'm pretty sure everything was in there right, cause it was working, so, what would cause it to go wrong like that?
