Re: Built custom channel for Soundcraft Boards (SSL like)
« Reply #20 on: January 11, 2017, 08:56:46 AM »
Here they are !
PCB and faceplate match perfectly.
I receive potentiometers too. Still waiting for the dual gang 2k5  ;)
dario84
« Reply #21 on: March 23, 2017, 07:38:33 PM »
this is awesome!!!
I am at the begining of moding my SC600 and I would love to incorporate a few of these channels as well!
so if I understand it works with the original desk?
if so are you going to sell the pannels and pcb?
« Reply #22 on: March 23, 2017, 11:02:21 PM »
this is awesome!!!
Dario,
The channel is in stand by now due to the impossibility to find the 2.5K potentiometer.
I'm thinking to replace the SSL4000 transistor Preamp by the 82E01 transformer Preamp.
Tell me how many channel you want ?
dario84
« Reply #23 on: March 24, 2017, 05:23:21 AM »
Dario,
I would take two! are you from europe?
D
Alcore
« Reply #24 on: November 17, 2017, 03:50:56 PM »
Hi, I just came across this posting. Nice work! Did you ever find any dual gang 2.5k potentiometers?  If you are going to make these in large quantities, you could contact a manufacturer and have them make the pots for you. They probably have at least a 500 piece minimum but you could search around and maybe get less.
-Al
Whoops
« Reply #25 on: November 26, 2017, 08:36:05 PM »
People use a 2.2K Rev Log pot for the SSL9K preamp, the only source I know of that pot is audiomaintenance:
http://www.audiomaintenance.com/acatalog/om%2d01%2d073%5fextended%5finfo.html
« Reply #26 on: December 02, 2017, 08:51:23 AM »
It tooks me a year to "finish" this project  (to many project at home... Anyway ;))
So here i am. My first prototype is fully working, Preamp, EQ, routing everything work  ;D ;D
I decided to update a little bit the channel and add some option like  24 busses, Group input and Mute/Solo control and group via MIDI or with a  "rebuild" master channel.
here is the design of the new channel: PAN and ODD/EVEN switch added near Pan potentiometer  to select busses and BUS switch on the top to use the channel as a bus/group.
I think i will make a kit include PCB, Panel, Potentiometer, knobs and switches.
Price will be around 150€ to 200€ ex shipping
Anybody want one ? ;)
« Last Edit: December 02, 2017, 09:21:20 AM by xarolium »
« Reply #27 on: December 03, 2017, 05:25:51 PM »
Maximum Respect!  :)
Whoops
« Reply #28 on: December 04, 2017, 12:25:08 PM »
Congratulations for your work.
Amazing stuff
So what preamp circuit did you use in the end?
« Reply #29 on: December 07, 2017, 07:43:09 AM »
Amazing stuff
The preamp is the SSL9K  but with a LM394 instead of a MAT-02 and it works like a charm.
Next prototype with 24 Busses are ready to go in PCB production ;)
Whoops
« Reply #30 on: December 07, 2017, 08:02:25 AM »
Same thing, both transistors are dual matched type, they are interchangeable
Not exactly the same specs, but I've built SSL9K preamps with both without listening a diference
« Reply #31 on: December 07, 2017, 11:54:34 AM »
Couple of questions. Are the push buttons mounted on one side of the PCB and the pots on the other. Is the faceplate a U shape or an L shape? Is it made of steel?
« Reply #32 on: December 07, 2017, 09:17:14 PM »
Push buttons and potentiometers are mounted on both side of the PCB. The face plate is a 1.2mm U shape Aluminium sheet.
« Reply #33 on: December 08, 2017, 04:56:56 AM »
That is very interesting. I have seen U shaped channels in steel but not aluminium. Who makes them for you?
john12ax7
« Reply #34 on: December 09, 2017, 04:32:48 PM »
Is the U shape for mechanical strength? Is a simple flat panel not strong enough?
This is super nice work.
Re: Built custom channel for Soundcraft Boards (SSL like) New
« Reply #35 on: December 09, 2017, 06:37:54 PM »
Over that length it is definitely not strong enough - even steel would most likely not be strong enough - the EELA mixer I recently acquired have steel U shaped channels over 12 inches long.
« Last Edit: December 11, 2017, 03:28:55 AM by ruffrecords »
jasonallenh
« Reply #36 on: December 11, 2017, 01:10:06 AM »
You are a crazy person and this is amazing
 ;D ;D ;D ;D
Successful builds:
G-Calrec
G-Pultec
GSSL
Igor's 4kCC
Poctop's u87
Matador/Chunger C12 (almost)
