my main concern was PSU requirements... stock 200b is pretty bare bonesNot to be a Debbie Downer but have we seen performance measurements for a fully loaded desk ?
Having designed consoles before sometimes you don't know what the problems are until you ask several tens of strips to play nice together.
Oui, juste c'est possible, on ne sait pas jusqu'où il est allé dans son projet, les posts se sont arrêtés il y a quelques années. depuis.....silence
Bon, si je veux changer mon AOP sur quelques pistes pour essayer sur mon 200b, que me conseilleriez-vous ? bavures brunes? J'ai actuellement des TL072.... et je cherche.... merci....
Merci, thanks for posting in English. I am unsure what you mean by AOP (perhaps op amp)?Well, if I want to change my AOP on a few tracks to try on my 200b, what would you advise me? brown burrs? I currently have TL072s.... and I'm looking for.... thanks....
I want at least 4 maybe 8It tooks me a year to "finish" this project (to many project at home... Anyway )
So here i am. My first prototype is fully working, Preamp, EQ, routing everything work ;D ;D
I decided to update a little bit the channel and add some option like 24 busses, Group input and Mute/Solo control and group via MIDI or with a "rebuild" master channel.
here is the design of the new channel: PAN and ODD/EVEN switch added near Pan potentiometer to select busses and BUS switch on the top to use the channel as a bus/group.
I think i will make a kit include PCB, Panel, Potentiometer, knobs and switches.
Price will be around 150€ to 200€ ex shipping
Anybody want one ?
>> If you or someone you know here in the U.S. could ship me one of these SOUNDCRAFT 200B or 6000 channel strips, I could then mechanically "Reverse-Engineer" it and not only create a 3D CAD-model of the channel strip metal work, but also create a fully-dimensioned "Sheet-Metal Fabrication Drawing" that most anyone could then use to have their own channel-strips fabricated. Knowing how long and wide the channel-strip is one thing, but also knowing the exact dimensions of all of where the hole cutouts are located, what their dimensions are, what the channel-strip mounting-hole counterbore dimensions are, etc., etc., etc., is a whole other matter!!! But, I could obtain all of that type of information -- IF -- I just had an actual unit right here in my hands. Any ideas and/or suggestions???Soundcraft 6000 faceplate measures nineteen inches long by one and a quarter inches wide.
Unfortunately my desk is in storage making it difficult. I'm also based in the UK not making it ideal to send over seas...>> If you or someone you know here in the U.S. could ship me one of these SOUNDCRAFT 220B or 6000 channel strips, I could then mechanically "Reverse-Engineer" it and not only create a 3D CAD-model of the channel strip metal work, but also create a fully-dimensioned "Sheet-Metal Fabrication Drawing" that most anyone could then use to have their own channel-strips fabricated. Knowing how long and wide the channel-strip is one thing, but also knowing the exact dimensions of all of where the hole cutouts are located, what their dimensions are, what the channel-strip mounting-hole counterbore dimensions are, etc., etc., etc., is a whole other matter!!! But, I could obtain all of that type of information -- IF -- I just had an actual unit right here in my hands. Any ideas and/or suggestions???
[Does the manual contain accurate technical drawings?] -- Generally.....NO!!! At least not to the level of detail that you see in my drawing in Post #114. What you see in my Post #114 drawing is the amount and type of mechanical details I need in order for me to create an accurate 3D CAD-model of the channel-strip. And.....this is what I would end up with if I were able to "Reverse-Engineer" an actual channel-strip, if I had it here in my own hands!!! Anyone???.....Just a thought.. Does the manual contain accurate technical drawings?
[I'm also based in the UK not making it ideal to send overseas] -- I certainly don't need for you to ship the entire mixing console over here.....just the piece(s) of metal that makes up the channel-strip!!! Would that be doable???.....Unfortunately my desk is in storage making it difficult. I'm also based in the UK not making it ideal to send over seas...
