Got an 1176 rev D here, which had some trouble. Recapped the thing, sounds much better now.
Also recapped the power supply, after which the DC voltage went up from 24V to 27V, after that I changed the lamps to the original ones, in there were 756 because the original 1819 weren't bright enough. However they seemed to draw too much current, now with the original 1819 lamps the voltage has increased to 29V. Without the lamps the voltage measures 30,5V which it should be, as there's a 30V zener to regulate it. However, with the lamps in, it doesn't come above 29V, at which voltage the zener doesn't do anything. Just to be sure I also replaced the rectifier diodes, but this didn't do anything.
Now looking at the schematic, the transformer is rated for 120V or (in this case) 240V. The mains voltage here where I live is 220V. The secondary of the transformer measures (under load) 28V, which makes it more or less a 1:8 transformer. Which should measure 28*sqrt(2)-1,4 = 38V after the diode bridge. However, (due to the lamps) the voltage there is now only 32V.
Could it be that the design requires those extra 20/8 = 2,5V from the transformer, which it gets with the 240V mains voltage. in order to get the proper 30V volts? Or am I overlooking something?
Any thoughts?
Thank you!
Any thoughts?
Thank you!
