"The proper way to do things is to dither every time you lower the bit resolution. This would apply for exporting but also internally as well. Every time you use a plugin, or even move a fader, there can be rounding errors. The DAW is constantly going from higher bit depths to lower bit depths. You can truncate these errors which creates distortion, or dither and essentially make it broadband noise"
I'm confused. What is it you are saying by "also internally as well"?
