Yap. I used ST7 from Farnell, link:
http://il.farnell.com/anders-electronics/st7/vu-meter-rect-0-200ua/dp/7758200?_requestid=182388
and printed the scale by myself.
Meter connected this way:
200 Ohm 1/4W resistor connected in parallel (across the meter)
Plus of meter goes to 680 Ohm 1/4W resistor
Minus of meter goes to front pannel, to pad marked (-mtr1) (next to bypass switch)
Free leg of 680R resistor goes to front pannel, to pad marked (+mtr1) (next to bypass switch)
All this stuff backlighted from bottom of meter (2xPLCC-2 red leds glued with 5 min sets epoxy).
LED's connected in series.
+VULED pad to + of first LED; - of first LED to + of second LED; - of second LED to -VULED pad.
It is a bit tricky to solder PLCC-2 led's, they are 2x2mm...
First glue them with small amount of epoxy, let glue set 5-10 min.
Glue piece of breadboard 5x10mm on back of meter.
Then pull some pieces from 24awg wire, connect led's in series,
then connect led's to breadboard...
here's terminals easy to connect to wires going from front pannel.
I like this meter. BTW, faster than Sifam several times...shows closer picture to real gain reduction.
Sifams are too slow, they don't show actual gain reduction on fast peaks.
Will post link to printable scale drawing and photos of backlighting stuff in few days.
Scale was generated simply by measuring gain reduction and marking the old scale with pen...as is
I took -20 db as last point of old scale...rest is simple.
