Just a quick question. Does anyone have a front panel designer file that they wouldn't mind sharing? I really don't want to mess up the control placement.
Feel free to mail about .cdr (Corel) files. It is possible to take the PCB dimensions
in .ps or .plt than import them into FPD. Check for conversion units, BTW, sometimes PLT
converted as 1000 and not 1016 units.
the bc177 i ordered at Farnell "Coil BC 177C nx" is the writing on it. with this transistors the unit was working and sounding good but way out of specs..
Hm... Strange. I used NOS BC179 in one unit, worked fine.
Anyone one use anything beyond the standard fair for transformers?
Me
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
TF10015/16, my outputs (Hi-B, gaped C-core).
Gave an attempt to wound input/interstage on DU2023 lams, 84% Ni,
loved them more for sound than 31267+Carenhill interstage.
Too many time investment, but worth this.
Less disrorted low-mid, still huge sound. Again, all these sound talks is matter of taste.
Input/interstage transformers IMHO better to wound on DU or UI laminations
(two symmetric coils), copper shield between windings must. Some trunny' woodoo as well
TF100XX are wound on EI laminations, BUT for me, sounded good.
The unit is working great now for two days ;-)
HURRAY!!!!!
But i have some concerns with the psu. The regulator gets really hot (after 30 minutes around 55^C) i useed on secondary of a 25V 2x0,6A Power Transformer. Should i use both secondarys in parallel so its 2x 0,6A or should this be no problem?
Use bigger heatsink, as it was suggested. 40-50deg C is OK.
The windings are in parallel or one half is used, but not series connection.
Yes, right, see it from your later post
if anything, paralleling the secondaries of your power transformer might slightly increase the voltage at the regulator input due to less current being pulled thorough the transformer, i.e. less "sag". it might cool the transformer a bit if that's the problem. but you are talking about the regulator heating up, not the transformer... yes?
Just...my $0.02, paralleling the windings is better for transformer. Less power going to heat etc.
i will add a much bigger heat sink to be save then.
voltage on the input pin of regulator is: 39,5V
Absolutely fine.
mine's almost done - i'll probably be running some audio through it this weekend... then i need to get a nice case happening!
Yummmm... Again, feel free to mail about .cdr file.
