gswan
Are the DC bias conditions correct?
Is the gain of each amplifier stage correct?
Have you calibrated it correctly yet?
gswan said:C16 is a compensation cap. It's not required if you are using a TL071 device. It can be found on op-amps like the NE5534 etc, which allow for external compensation.
onlymeeee said:R84 is for termination of the transformer.
Whether it's needed and the ideal value depends on the transformer you're using and also what's next in the chain.
If it's unterminated it can cause ringing or overshoot. If you add too much, it can reduce the headroom and high freq. Maybe even overload the output.
The best way to decide is to apply a 1khz square wave and observe what happens.
What transformer are you using?
The F version used a B11148 trannie and doesn't have a termination resistor. They changed the trannie on subsequent versions which then had a termination resistor.
casrec said:UA just feeds A pot from the Input trannie.
