T
thecheat
Guest
right on, thanks guys.
in that case,
THESE THINGS RULLZ>
Chris
in that case,
THESE THINGS RULLZ>
Chris
ChrioN said:Having a small problem and couldn't find the answer to it, despite the improved search function...
When I turn on my unit, the needle gets to -2dB. It takes about 5 minutes or so for it to reach 0dB. Why is that? (This is in GR-mode)
living sounds said:I've just realised the meter is working correctly on that unit. It's 'only' the audio path that doesn't get compresion. Changing the input, attack, release etc. results in correct meter behaviour. So this part of the circuit should be OK. I've triple checked all connecions and still found no error. Where to look? Does the unit still pass audio when the FET in the signal preamp is broken?
gswan said:Sounds like the GR FET is broken or inserted incorrectly.
In which case you can't possibly have biased it correctly.
user 37518 said:Ok guys i already posted this, but since im new around here i thought of re-asking it here. My ratio board on my finished G1176 Mnats J rev is very weird. When im at 4:1 ratio, the threshold seems very low (input knob must be set very low otherwise it will start compressing like a mad man) but when i move to the upper ratio positions, for instance 12:1, the threshold seems higher and it compresses much less. This can also be observed on the ouput setting on the Meter. As i go higher on the ratio i have more output, as i go lower, i have less output. I checked all resistor values and wiring and it seems to be OK, also the rotary switch is a 5pos, 2 pol Alpha wired according to mnats pictorial. So what could be wrong??
Ohhh so the 4:1 setting should be compressing more than the 20:1 setting if they are at the same input level?onlymeeee said:user 37518 said:Ok guys i already posted this, but since im new around here i thought of re-asking it here. My ratio board on my finished G1176 Mnats J rev is very weird. When im at 4:1 ratio, the threshold seems very low (input knob must be set very low otherwise it will start compressing like a mad man) but when i move to the upper ratio positions, for instance 12:1, the threshold seems higher and it compresses much less. This can also be observed on the ouput setting on the Meter. As i go higher on the ratio i have more output, as i go lower, i have less output. I checked all resistor values and wiring and it seems to be OK, also the rotary switch is a 5pos, 2 pol Alpha wired according to mnats pictorial. So what could be wrong??
Nowt. On an 1176, higher the ratio, higher the threshold.
gswan said:Now measure the output of the GR amp and the FET Vgs and see that they are the same, whilst increasing the input signal to start compression. If your meter is showing compression GR operation, then the GR amp is probably working OK.
the only thing that bothers me, is that for example when im 4:1 in an X amount of input gain, my GR meter will display something like -10db of gain reduction, while on 20:1 with the input gain in the same position, wont even move a little bit from zero.
living sounds said:Did that, both FETS and the GR amp seem to be alright. They also roughly behave like the second half, which works OK. What else to check in this situation?
gswan said:Well then I guess that unless the GR FET is not connected to the signal line on the Drain, then it's working OK.
living sounds said:The FET is not the problem. I'm at a loss what to check...
MartyMart said:living sounds said:The FET is not the problem. I'm at a loss what to check...
Have you pulled the board out and checked for any "cold" solder joints in that area ?
MM.
living sounds said:Yes, I've even resoldered many connections just in case. The problem is my limited understanding of the compressor's topology. Am I correct in assuming that no actual audio signal runs through the GR amp, just a control signal? Where on the board does this control signal actually 'happen' to the audio signal?
