s2udio
this one ?
http://www.equinoxsystems.net/DIY/SG-1176-RevD-Wiring_ALLv3.pdf
SIXTYNINER said:same reply : file damaged or corrupted
SIXTYNINER said:ok now link work and pdf can be downloade but when i try to open pdf it say same things.......
JoleFIN said:Can someone draw the wiring of Mnats Rev F + Hairball Pushbuttons for me???
JoleFIN said:###1. I have the input pot still unwired, where do the wires go?
The pot pins from the backside, where do I connect these?
____
ı O ı
ı___ı
ı ı ı
1 2 3
JoleFIN said:###2. Also, where do I connect the "Attack Pot (GRN)" on the ratio board?
JoleFIN said:###3. And what do the "GRN" and "BLK" stand for on the Hairball board wiring guide?
Echo North said:You probably need to step away for a day...clear your head.
Echo North said:Do you have the .pdf I send with my boards?
JoleFIN said:What do the Zero Adjust, Dist Trim and Tracking Adjust trimmers do exactly?
intercorni said:Hello,
where do I get the Attack Poti (22K Lin) with a switch?
JoleFIN said:Thanks Mark, the meter is now at least working in a more useful range!
I didn't get the GR meter tracking done right though.. the startup settings say "Output fully CW", but line #5 says "Turn the output level control CW until the meter reads 0VU", so I was wondering which one should be stated "CCW" (obviously there's a bug here?). Couldn't get a proper -10dB drop with the calibration when turning GR ON/OFF, the tracking trimmer run out of range first. Because I've built it on the Mnats Rev J board, is this part even neccessary? I tuned the tracking to CW and the zero adjust to -10dB when feeding it with -10dB 1khz sine signal and I'm happy with what the meter gives me when limiting material.
Biasrocks said:Yes, that refers to the ability to turn off gain reduction on the original unit by turning the Attack pot to the off position. If you haven't incorporated the switched pot into your build, you must disable gain reduction by using another method. You must short pad 22 on the main PCB to ground to disable GR.
JoleFIN said:Since I've used alternate wiring for the meter push buttons I can disable the GR with the OFF button (the unit is always powered, I have a main switch for all gear at the moment but will get a separate switch for this part of rack), so it's no problem.. but it doesn't give the -10dB drop when I turn the GR ON/OFF.
I was also wondering should the meter needle start from 0dB and turn downwards when limiting in GR meter mode? Now it's running like in VU mode, but naturally showing the amount of gain reduction instead.
Biasrocks said:Right, doesn't the OFF position simply disable the meter?
