emreyazgin
casrec said:I would check all of your transistors. I ordered two different transistors from mouser and the data sheets were wrong. Shocking I know. Any who, you can use you DMM and the diode tester to easily check the orientation. Here is a link on how to test.
http://www.kilowattclassroom.com/Archive/AN0007.pdf
I kept frying R35 and Q5 was getting super hot because Q9 was the wrong way in.
Just checked using the method in the PDF, they are ok, I haven;t check ALL of them, only the ones around the output drivers for now, as I have the problem of heating up of the drivers. Both the health of the transistors and the orientation seem to be fine.
