Hi everyone,
I've just finished assembling my very first 1176 Rev.J using a MNATS board and Cinemag O/P trafo.
I'm a complete newbie in DIY, so I bought a kit of parts, case, trasnsistor, trafo, etc. plus instructions from a local italian dealer who sells MNATS boards too (shame on me!).
Being a newbie, I didn't check all the component values before assembling the board with components and I trusted the labels put by the reseller.
I followed the instructions and the labels and I completed the board and the whole unit.
Without the ICs in their sockets I measured correct "first check" voltage values (+30 and -10).
Then I placed the ICs in their sockets (following the paper labels made by the seller).
I checked the previous values again and they do not match anymore. No smoke, no bad smells.
Looking at the schematic on MNATS site, I soonly found out that the TL071 and the NE5532 were inverted (shame on me again!) and I learnt not to trust paper labels anymore.
I replaced the ICs with new (and correct) ones, I checked for bad solder joints but everything seemed to be OK. I measured correct values again (+30 and -10).
I followed calibration instructions measuring levels with a NTI Minilyzer.
I had some issues calibrating amplitude levels between the meter and the Minilyzer but I decided not to concentrate on this since I measured correct values regarding compression and I finished calibrating the other trimmers.
I started testing the unit with music.
Everything seems to be ok soundwise. Attack and release are working as they should, I can hear a true FET compression (I've used a real 1176 several times). The actual sound it's pretty good.
Problem is, I'm having some strange behaviour on the input stage.
Briefly, it seems that the input is about 10 dB more sensitive than I remember, as the unit starts compressing way too early (referring to knob position) compared to the silverface one I used often in the last few years. I admit that I haven't been able to A/B them yet.
I decided to check again for component mismatching using Gyraf schematic and BOM as reference.
I checked all resistor colors and I found out that R33 is a 4K3 instead of an 11K (I'll never buy again from this dealer!!!
I also measured all the voltages mentioned in Gyraf schematic and I don't see any serious deviation from written values.
In the meantime, I discovered this board and I started reading some of your discussions.
Any help from board members is appreciated.
Is this input sensitibity a "common" behaviour in Rev J clones?
Is it possible that I damaged some components during IC mismatching?
Is it possible that R33 is causing the sensitivity problem (though it is not in the input stage judging from the schematic)?
If needed I can attach/send the voltages I measured compared to the ones in the schematic and/or explain more in detail calibration and measurement procedures.
Thanks!!!
