As originally conceived by Jakob, the Lundahl input transformer option is configured as a 1:1 ratio circuit. PRR pointed out in his post that a step-down configuration is preferable in this circuit. This is easy to accomplish with my latest revision boards.
Lundahl Input Options
Find the area just to the right of the transformer like the above image. Cut the trace marked in red on the reverse side of the PCB. It is easy to find as it runs diagonally and is thinner than the other tracks. Now run wire links between the pads as marked in blue. The two resistors marked R*1 and R*2 are not installed in the 2:1 configuration.
Next, install the Lundahl LL1540 input transformer as usual. It will now operate as a 2:1 stepdown transformer.
