gswan
Did you attempt a calibration to check if the unit is still able to be calibrated? This will show if the GR FET is operating or not.
I was also thinking of doing that but i simply swapped the fet's first. When i build it i used cutdown IC sockets for the FET's so swapping was really easy and i had some bf245's left.gswan said:Did you attempt a calibration to check if the unit is still able to be calibrated? This will show if the GR FET is operating or not.
??dagoose said:Both 24 +/- are OK
dagoose said:I was also thinking of doing that but i simply swapped the fet's first. When i build it i used cutdown IC sockets for the FET's so swapping was really easy and i had some bf245's left.Did not work.
dagoose said:I have to check what happened exactly, but yesterday evening i found out that the led and resistor on the -24v side (mnats lm317/337 psu) where both burned down so i'm suspicious about the psu. Both 24 +/- are OK but the led and resistor are not going to burn down just like that. Could be something like a spike? :-\ I also noted that the transformer is mechanically humming.
What i think is strange is that both channels behave exactly the same so this could be the reason.
But still... why does it still pass audio fine and do the meters react to the GR while there is no GR? :-[:-[
gswan said:dagoose said:I was also thinking of doing that but i simply swapped the fet's first. When i build it i used cutdown IC sockets for the FET's so swapping was really easy and i had some bf245's left.Did not work.
Can't see why you would think that would work. Since the new FETs were not matched to the old FETs the unit would need complete recalibration. You probably have a bad connection on the socket for the FET too. Dump the socket, select and match the FETs and solder them in directly.
As noted, the power supply should be +30V and -10V, not +/-24V. Sounds like you have a few problems to sort out.
dagoose said:But.. it passes audio fine, the meters are working fine and they respond to the various attack/release settings but there is no compression going on.
dagoose said:The psu was set to 24v +/- while it should be +30v/-10v. After reseting the voltages to the right values it came alive right away! (not even blown up parts) ;D
I still think it's funny that with the 24v it was passing audio and showing GR on the meters but you didn't hear compression going on. Any idea how that could be the case? ???
audiophreak said:Thanks gswan,
I've never done this before , so if i understand you correctly , I continue to drop Vds by another 100mv , measure Vgs again , and then drop another 100mV and so on ... say maybe 5 or six times, and then plot all those readings to get a " Slope " ?
