Rob Flinn
i have a voltage on m+/m-
value depends on unit bypassed (0)
or in gain reduction mode and adjustments of
gr pot and tracking pots on pcb...
The easy way to check whether you have a faulty meter is to check it out of this circuit like I said in the previous post. If it works when you you hook it up to maybe a CD player, then you know you have a fault with the 1176.
Does your 1176 pass a signal? If you have the meter switch set to output then the meter is just connected to the output of the 1176. If the 1176 is passing audio & you have proved the meter to work out of this circuit then it is likely that you have a problem with the meter selection/bypass board of wiring.
In gain reduction mode the mater action is affected by all the things you said, but also the FET byass adjustment.
