So the DC levels change at point7 with ratio, and stays changed?
The second part of the ratio switch, with R42-43-44-45-46-87 and C21, adds different negative bias'es to the anode (-side) of the FD333 diodes. This is the "threshold" to be overcome before the two FD333 diodes conduct and start gainreduction.
Check your DC voltage at point 21 with no signal. It should be between 0 and -10V, but in any case below 0V.
Try lifting one end of both the FD333 diodes, and recheck if ratio alters gain (it will change a little, but not much). If so, then the ratio setting affects the "Q-bias" - possibly because of an error around R74-75 and C21. Check orientation of C21.
Also, this could be because of an error in either C19 or C20 - if one of these are leaking DC, then you'll have constant over-threshold DC at the input of the diodes.
Jakob E.
Jakob E.
