What are you using as a test signal? The 1176 has loads of gain and even with a -20dB input you should be able to easily peg the VU meter.
Try removing Q1 and seeing what that does to your output strength.
Using a 1KHz signal, at approx 0dB (measuring AC at my input read 0.777 VAC), which was loud enough to send my mixer skyrocketing
I never got the meter moving much/at all.
With Q1 in, I adjusted the output so the meter on my mixer is reading 0dB. I then pulled Q1, and got the exact same level on the mixer. I changed between modes (i.e bypass, GR and VU) and ratios, and the output strength never changed :?
I get the impression my compression sidechain just isn't getting activated at all.
But with Gain Reduction ON, you should have plenty of audio at, say, the emitter of Q15 just before rectification. If not, something is wrong upstream.
No audio there, unfortunately. I re-checked my power supply voltages (all good), and the voltages at Q12-15, and still all good.
Seems very unlikely that both your FETs are faulty. More likely that the common circuit controlling them is where the fault lies.
Could it be a faulty Q-Bias trimmer? I am looking in the right area for the common circuit?
I'll keep hunting! Unfortunately I only ever seem to get about 10-15 mins at a time with it :sad:
Thanks for the help, Mako
