hey brian... go for a 10k there.
the original revisions of the 1176 that the g1176 is based on had a 10db step up at the output, and this is why, on mnats board, the output transformer is wired 1:2, to get 6db extra gain to closer match the original.
to do that, on the output, just install the oep as it is on the board. If I remember correctly, the input transformer is wired 1:1. On the original, there was no input transformer. On previous revisions that *did* have an input transformer, it was wired 500:200. There are a lot of posts about all this, but basically, try it out as is.... see how you like it. If you feel you need to hit the compressor a bit lighter, you can try wiring the oep off board with a stepdown.
If you want, you can also install a couple pins on to the board so that you can use alligator clips on an upside-down oep while you try different windings and experiment before commiting with the soldering-iron.
its a picky issue, and you have to decide what you like and how you prefer to use the tool. if you haven't yet, print all the relevant material, like the schematic, the pcb layout from mnats site, and the oep datasheets from the oep site. these are invaluable while you are working on it, especially if you experiment with windings amd ratios
billy
