It's a noise that happens when the compressor starts to compress. The side-chain sends a voltage that changes gain. It also is superimposed to the signal. Since it's applied symetrically to both phases of the signal, it can be eliminated by using a differential amp or a transformer. In practice, elimination is not perfect.Sorry for my ignorance...
what is common mode thumps? is something audible or is referred to a sort of electronic behavior?
thanks for attention
best
I'm not understanding what you are trying to solve?so if i understand a solution is to add a sort of 2 stage inverting follower from sidechian to diodeBridge... right?
Your compressor has a 3 op amp instrumentation amplifier after the diode bridge that takes care of the common-mode voltage.To avoid this common mode...
apparently I didn t noticed at listening... But not so expert to judge
Note that CMRR in opamp specs has very little to do with CMRR in a balanced connection.I was looking at ne5532 cmrr value
Now i see the difference between the 2 projects and why one uses a transformer and the other doesn't. Thanks!Your compressor has a 3 op amp instrumentation amplifier after the diode bridge that takes care of the common-mode voltage.
thank you so much for your infos and seggestions....
i m reading this , Designing for high common-mode rejection
in balanced audio inputs, by texas inst.... to go in details
best
So this referred to the transformer and diff amps already in the schematics ? (Which are there to control/tame/reduce thump from being fed back into the SC, where it might trigger non-program material derived 'over'-compression.)BTW, thumps could be reduced by using balanced control voltage.
Thanks i ll check!Take a look at the THAT corporation literature on this.
That's a suggestion I made a couple of posts ago, however I don't think it's that useful in practice. Note that it's what the Siemens U273 does, albeit with a different bridge arrangement.Or instead of hooking diodes to ground, hook that side to CV-inverted, as in driving Ec+ and Ec- of a VCA ?
Do you have the "simplified" schemo. What did you simulated it with?I ve simulated the U273 vca... The simplified version on sound au... The waveform at the output looks like is passing through a clipper, very rounded
Did you simulate the one on fitg 10 or in fig 10b?https://sound-au.com/articles/vca-techniques.htmlHere is the link... It was my starting point for dbComp too
