Hello Audiox,
Do you have for sale PC boards for this summing amp ?
I would be much interested.
Guy
Guy
guy_4 said:Do you have for sale PC boards for this summing amp ? I would be much interested.
substitute said:Audiox, could you please explain the equations in the block diagram, I'm embarrassed to say not only do I not get them but I don't get them so thoroughly I don't even know what to google to figure it out for myself.
substitute said:it's been a long time since high school math, what's the story with 20 log?
conleycd said:I'm wondering if this arrangement in the balanced to unbalanced allows for extended headroom because you would have the swing of each opamp?
conleycd said:Do you know what the clip point would be if I used say OPA2604s at +/- 24v?
Kir_For_Pleasure said:maybe i read the gain graph totally wrong.
moamps said:values for the R13 and R19 on the schematic and layout are 20k,
moamps said:but all calculation and graph are made using 10k. ???
MrZpliff said:Should one worry bout DC on the output ? There are no output caps. Suppose they're not needed. Just wanna check :![]()
keefaz said:Is there an advantage in using both sides of dual opamps across the 2 channels rather than using one dual opamp for each channel in this balanced input design?
Crosstalk wise, wouldn't it better to just use U1 for channel 1 and U2 for channel 2 ?
audiox said:MrZpliff said:Should one worry bout DC on the output ? There are no output caps. Suppose they're not needed. Just wanna check :![]()
Depends on your application. If connected e.g. to a relay or potentiometer it is a good idea to add the capacitor.
