Matthew Jacobs
strangeandbouncy said:You won't regret building these puppies, I promise. they really sound great.
Well, it is Neumann after all... ;D
I'm hoping to get some from Gustav and a Studer 169 5K as well.
JD
m.gharibe said:hi there
can resend schematic another place?
im iranian and cant see your schematic
irfrench said:I've just put one of these together and am getting R8 burning out ;D ??? . Is there anything obvious you can think I should check for before I start debugging What wattage are you using for these?
iprovlek said:I built 5 of this opamp and cant get them works! I solder every element like in schematics and dont know what i missing......
mitsos said:Check your 212s... if you didn't use motorolas, flip them around.strangeandbouncy said:perhaps there are different versions of the transistors with different pinouts
iprovlek said:Finnaly i got two of this Neumann OA10 opamp to work!
It was hard to get measure this outside,cause dont have COM!
But after few fliping i get the work,212 and 182 transitors are the same as schematics,but i must flip 327 and 337 to get it work....
And thanks again Audiox for this great opamp!
I compare it with old Philips 5534 , and OA10 rules all the way....silky an beatifull...
gyraf said:yes, should be the same, just tolerating higher voltage
