labak said:Funny you are saying this : if I turn the Vu trimmers to have 5V at F points, Sounds opens up a bit and get louder a bit, but needle is pegged. If I go to 24V at F points, sounds get thinner and quieter, but needle move to the 1rst number of the scale. Always on that kind of 10khz HP sound.
Rob, did you get your unit working with edcors xsm 10k/600?
I have clamped XLR straight at the secondary of them and same issue, 10khz Hipass sound. Both Channels.
I didn't build with these pcb's, I did an exact RS124 point to point. Therefore my circuit isn't exactly the same as yours, but it's pretty close. When I was getting my units going I used edcor outs as I happened to have a pair in my spares box & it worked, but I didn't specifically test the HF response, it was more an osc & scope test mainly at 1KHz. I was only using the edcors on the output anyway because I had some nice Gardners inputs knocking around. I have subsequently changed the edcor outs to Sowters.
