sage said:
Hello there
almost completed the build - just double checking on a couple of things....
PARALLEL WIRING FOR TRIAD VPT 36-1390 115VAC :
INPUT : BLUE AND VIOLET TIED TOGETHER - GREY AND BROWN TIED TOGETHER
OUTPUT TO THE BOARDS: BLACK AND ORAGE TOGETHER - YELLOW AND RED TOGETHER
THEN YELLOW/RED and ORANGE/BLACK GO TO BOTH INPUTS ON PCBs AT THE SAME TIME INDIVIDUALLY
ALSO DOES ANYONE HAS PICTURE ON HOW TO WIRE THE LINK BOTTON ?
THANK YOU
Sage
Looking at the data for your Triad transormer you are correct about the primary connection.
On the secondary you need to create a center tap by connecting red and orange.
So now you will have three wires to your board insted of two. BLACK, RED+ORANGE, YELLOW.
There should be 18V AC between your center tap(red+orange) and black wire.
The same goes for center tap - yellow wire.
Then you connect the two boards in parallel. That means you split your secondary AC wiring so
both boards get the same power. I use some kind of screw terminals to do this in the back of the case.
Don't forget to trim down your voltage to +/- 15V DC before you insert any IC's.
Link button: if you search this thread you will know where to connect the cables to the PCB.
Connect the two cables to the link button, one in the middle and one to the "engaged" (closest to PCB).
"Not engaged" (closest to front panel) left alone.
You have to press both link button and one of the other buttons (IN/GR/OUT) on that channel
to get a reading from the VU.
Set controls on both channels to the same.
Good luck!
//Magnus
