Hi!
I've started shopping parts for my V3 board.
I noticed that BOM file for THAT build on the first page is not the same as BOM included in V3 pdf!
When I bought resistors from the
CLX_VU bom THAT CHIP.pdf and stuffed most of them, I noticed that some are missing. Then compared it to
clx_manual_rev3.pdf and saw there's a difference. So advice for everyone - make sure you use latest BOM!! And that would be the one included in manual_rev3 document!
Now I have few questions.
1) Some resistor values are unobtainable in my local shops. If I for instance need 23K2 value, is it ok to use two resistors in series (22K1+1K1) or in parallel (2x47K)? I have this issue with values 23K2, 6K04, 5K49, 133K, 22Meg.
Whould there be issues if I do paralleling and serial connecting to achieve required value?
2) What if I use closest obtainable value? For instance if I use 6K19 instead of 6K04, since this 6K19 actually measures 6K13 would that be okay?
3) Also I have weird situation with 4M7 resistor (R52). When reading color code on it, it says it is that value. But when I measure it with my multimeter I get 5M6 value. That is too much off! Should I trust its actually 4M7 and assume my multimeter is acting weird on such high values (it is set to max 20Meg range... can't use lower setting since lower is 2Meg)?
