Compact desktop line mixer?
Front Panel designer can export an entire panel as a dxf file but I think it can only import a panel outline which may explain the errors. I have never tried importing an entire panel in dxf format into front panel designer. I posted it as dxf mainly for the benefit of @darth fader who I suspect is not familiar with front panel designer but is with dxf
When it comes to the engraving of text and so on, I no longer specify engraving because it is expensive and limited. Instead I specify UV printing which I have found to be just as durable but a lot cheaper and you can easily do graphics if you want to. I don't know if Frank can do this yet.
I am having breakfast at the moment (it is 9am here) using a laptop so I don't have access to the fpd file. I will post it later today when I get over to the workshop.
By the way, the panel thickness I chose was 2.5mm and there are no corner radii - the panel is rectangular.
Much appreciated Mr Ian! You are correct about not being familiar with front panel designer and I can load dxf files directly into "my" Proto Trak dpm rx3 milling machine here at work
The tepid response here (and the apparent lack of commercial products) might indicate there is little interest.
I can imagine a DIY building block system that could be used for OTB mixers, or a sub mixer for a synth rig. I even poked around at Mouser checking out prefab wiring solutions to connect front panel parts to a PCB(s).
I would be interested. I've wondered why there hasn't been more DIY projects along these lines.
I think a pseudo 500 series version of a project like this would be great (1.75" panel width, each channel an individual PCB) that could be built into a desk with 500 pres and modules. Wouldn't necessarily need to be limited to 3U high if more controls are needed.
A fader & balance pot, switches, and some aux buses. Cost would be low. Then each channel pcb could connect through bus wiring to a mix and bus output amplifiers in a separate enclosure.
I've wanted to build a module desk for some time and this would make it possible.
FWIW, I've been noodling around in my brain on this concept. (After a 13" snowfall here in KS, I've been house-bound since last weekend. At my age, shoveling that much snow from my driveway is just asking for a heart attack...lol!)
shrug.....
Bri
FWIW back in the 80s I evaluated offering a modular mixer kit series through my kit company.
In hindsight I'm glad that I demurred.
This is why I joined my first forum this year... I need one of these lol
I was doing some graphic design work for a company that was making a small desktop line level mixer, with automation/recall. I have the entire manual here still, I created the manual. This was about a year before covid. Covid hit, and everything shut down... and um, well. I know someone bought the idea, and I don't see that they have released it yet. It also offered balancing and enough makeup gain for racked gear that was lacking the output amp section. It was a pretty cool little rig - it was set up to work with your DAW.
I'm doing something similar to what @13engrsapper suggests, but it probably will not be as compact as OP desires as it's based upon a live board (channels removed, center section put in a narrower enclosure/built into a desk). It will be cost effective because it was picked up for a rather good price, and is of known sonic quality. Basically the back panel needs brought up to the top for I/O, and the power supply relocated, but all doable.
I'm up north in Dyer Indiana Close to chicago... which makes me a "Region Rat"
fwiw imnsho this site/forum is one of the best. Much top grade knowledge, support and advice. Even from people with whom I might / have disagreed on wider ethical / political issues.
OTOH do not invoke the wrath of the "bus(s)" police 🤣. Audio Phoolery also gets short shift 😳
Maybe just modify or use an old broadcast board? Look at some of the Auditronics, Wheatstone, Harrison, etc., any that had removable channel strips. As Brian mentioned, stay away form things which are one giant PCB OR one giant faceplate... "pain to maintain"
Right along the lines of what I was thinking. But I'm not clear if OP is up for a DIY solution or only a ready made commercial offering.
90% of my gear is DIY. If there’s an affordable commercially-available product, I wouldn’t say no to it though.
But if DIY, then the trick is to determine the best path forward. I could definitely repurpose an existing mixer of some kind, but then I’d have to match the control set (or at least, the holes and labels) that already exist. Building fully from-scratch could be fun from a circuit-design perspective, but I hate metalwork.
