Well he might not be very familiar with compressors, but how could that be. Anyway I sent him a message explaining what I meant just in case he decided what I posted was enough to drive him away from the thread.I didn't see any problem in your post, neither I see how could it be misinterpreted.
I dont know what the problem was to be honest
It must be hard when you invest in a board that runs you up in the six figures and a kid with an el cheapo DAW like Reaper can blow you away if you're not extremely careful. Blow you away as in create a more exciting mix (gotta be careful with what you say in today's climate)
Fascinating. The downside of OTB is when there is prominent deep low end like in hip hop. It’s almost impossible to make an accurate transfer through an DA/AD loop if you want to keep exactly what’s there.
You have to draw the line at some point, and if someone crosses that threshold, there are consequences directly proportionate to the level of trespassing.Who are we "attacking" at 12 o'clock?
And why do we "release" them at 11 o'clock?
What did they do to us?
I'm also concerned about what happens during the time (I assume it's 11 hours) that we're holding them, among other concerns of course.
Edit: the use of the word "slam" doesn't bode well to me either.
I'm out.
For gentler transgressions, the soft knee will suffice; for more persistent offenders, the HARD KNEE could be called forYou have to draw the line at some point, and if someone crosses that threshold, there are consequences directly proportionate to the level of trespassing.
IMHO it depends on the AD converter. I have found most to be lacking. Modern ones almost always have a digital high pass to get rid of DC offset installed that ruins the sound for my ears. I am aware of a handfull of converters that keep most of the low end intact, and they tend to be older and very pricy.One interesting difference I’ve found between mastering ITB and OTB is a low end connundrum. It’s much easier to shape low end OTB and give it all the good adjectives. The downside of OTB is when there is prominent deep low end like in hip hop. It’s almost impossible to make an accurate transfer through an DA/AD loop if you want to keep exactly what’s there.
These filters are usually set at about 1Hz. Can you hear it?Modern ones almost always have a digital high pass to get rid of DC offset installed that ruins the sound for my ears. I
I use a Prism AD2 which has the most accurate low end I’ve run across. It’s still not 100% accurate.IMHO it depends on the AD converter. I have found most to be lacking. Modern ones almost always have a digital high pass to get rid of DC offset installed that ruins the sound for my ears. I am aware of a handfull of converters that keep most of the low end intact, and they tend to be older and very pricy.
Have you tried DCS and Pacific Microsonics?I use a Prism AD2 which has the most accurate low end I’ve run across. It’s still not 100% accurate.
Not to be a troll, but what exactly is an accurate low end?I use a Prism AD2 which has the most accurate low end I’ve run across. It’s still not 100% accurate.
Can you hear a difference between the source file and the source file through the DA/AD loop. If you can hear a difference the loop is not accurate.Not to be a troll, but what exactly is an accurate low end?
I’ve never tried a DCS but I like the AD2 better than the PM2Have you tried DCS and Pacific Microsonics?
I tried some of the Lundahl amorphous core line input transformers. There is something about them I don’t like. I can’t quite put my finger on it but I prefer the regular Lundahl line input transformers.will spend my time procuring these amorphous c cores from Bridgeportmagnetics.
Interesting, I don't think I've heard / read that before.I’ve never tried a DCS but I like the AD2 better than the PM2
Yes. Not because my hearing extends that low, but because there is an audible change in the presentation, a blurring of the image. I hear it in AD and DA converters (the ones that give the opportunity to turn this filter off) and also with EQ plugins.These filters are usually set at about 1Hz. Can you hear it?
