D-47 Tube Mic Kit DIY Solution
FLEA 48 with Dany's D47 headbasket assembly - perfect fit and works great:
Looks very interesting.  8)
For the VF-12 / 14s, what transformers are currently available?  Is AMI still making theirs?
yes they are but there is other option too the AMI BV8 classic if very popular  , i have three different PCB that supports alot of different transfomer as well,  haufffe,cinemag , and others ....
best,
Dan,
hi Folks , for those who are building the mic , i have found that putting a small dab of epoxy on the contact tongue inside the headbakset eliminates a resonnance cause by it , as it might be confused with an Mbira instrument from africa,
also using a little dab of epoxy on the screw thats hold the tongue will prevent any shifting during years of operation ,
I am almost ready to release the third batch , i have prepared a little temporary webpage to checkout the offered options,
http://www.vintagemicrophonepcbkit.com/OrderD47.html
Dan,
JessJackson said:
havnt visited this forum in a minute but WELL DONE bro. Looking sweet!
yes i have done it the last minute you were off  this site ,
BEst,
dAn,
Mechanical Mic  kits are back in stock, :)
Matt Head Style is Now Available Limited Qty initial run
D47 Mechanical Kit
For the First Time U48 is also available in limited Qty initial run
U48 Mechanical Kit
Best
Dan :)
If I built an EF47 kit, with the power supply, would I be able to use that power supply with the EF version of this?  I am wondering about the pattern switching, since this has it on the microphone
