mrgrooves666
You need a locknut/preassure washer in there, that is what I did on mine to fix the loosening.
Well, I think I may have answered my own question, but the answer is no good.I'm running into a similar problem. My mic body came with switches, but they don't fit the PCB. @poctop - do you know the part number for the switches that fit the PCB?
what about this one ,Well, I think I may have answered my own question, but the answer is no good.
From the footprint dimensions and data sheets, it seems that the original switch was an E-Switch EG2205, which is now obsolete and I can't find them anywhere. The general replacement (and the ones included with the body I bought from Shengyin) seems to be C&K 0S202011MS2QS1. Unfortunately, the footprint is different.
So for anyone else wanting to build one of these...this may be a road block.
Also of note, my body did not come with the internal M/F stand-offs (it did come with the tapped F/F standoffs for the capsule deck). Those were easy enough to source though.
That's the replacement one that I designed my new board for. It's only 8.6mm x 7mm and the pins are spaced 2.5mm x 2mm. Your board is designed for the E-Switch EG2205, which is 12.6mm x 6.8mm with a pin spacing of 4mm x 2.5mm.
Edit: Here's the E-switch data sheet (scroll down to EG 2205), and here's the C&K data sheet (dimensions on the top of page 3)
I have finally found a batch of switches for this project and current switch board , i will offer them with the kits once they arrive here ,I see said the blind man. i will enquire to see if 3U audio still have them , i worked with Guosheng for this design when i did it ,
Dany,
Hello , i recieved the pcb today but no switches inside , is it different switch pcb ? have a great dayI have finally found a batch of switches for this project and current switch board , i will offer them with the kits once they arrive here ,
Dan,
https://www.mouser.com/ProductDetail/CK/0S202011MS2QS1?qs=xWNScUPc28raUWPVO/9Vdg==are those switches ok for your pcb ? also if You have reference for the other componants not featured on the original BOM ( i did order from the BOM for the square pcb a while ago) , i would be very glad . Thanks a lot in advanceI have finally found a batch of switches for this project and current switch board , i will offer them with the kits once they arrive here ,
Dan,
@vinylwall's post on page 3 of this thread (https://groupdiy.com/threads/d47-fet-new-body-style-pcb-now-available.82672/page-3#post-1075172) has all your answers.Can someone tell the references of the spacers and washers between the pcbs ( m2.5?) as the body from aliexpress dont get those included , nor the switches , Thanks a lot ( also references for the headers between pcbs would be more than appreciated too )
Thanks a lot , i will try to find an alternative , if not possible then i will contact You , my problem is i m in Japan and stuff take a very long time to arrive (except from CHina ... lol)@vinylwall's post on page 3 of this thread (https://groupdiy.com/threads/d47-fet-new-body-style-pcb-now-available.82672/page-3#post-1075172) has all your answers.
As for the switches, you either need to order some of the original switches from Dan mentioned above (they are no longer available anywhere else), or you need to use one of the boards I made with the C&K switches that are currently available.
what do You think of this one ? https://www.citrelay.com/Catalog Pages/SwitchCatalog/MS2205.pdfI have finally found a batch of switches for this project and current switch board , i will offer them with the kits once they arrive here ,
Dan,
Yes, it looks like the MS2205 part will work (same dimensions as the E-Switch EG2205 that I found). You may have to check the actuator length though to figure out which version to get. Shorter is probably better.what do You think of this one ? https://www.citrelay.com/Catalog Pages/SwitchCatalog/MS2205.pdf
there are 2 , 4 and 6 mm avalaibleYes, it looks like the MS2205 part will work (same dimensions as the E-Switch EG2205 that I found). You may have to check the actuator length though to figure out which version to get. Shorter is probably better.
