Skylar said:
MagnetoSound said:
Skylar said:
When we do the next run, my goal is to re-design the end connector to use an equally high-quality amphenol/tuchel connector which will be less expensive and more readily available to you guys.
Will this be the same pattern of connector?
It won't be compatible with previous EQU47s, but if a new connector ends up being used, I'd like it to:
• be at least 7pin or more
• rated for 250V / 3A+
• screw-locking design
• interchangeable with standard 3-pin neutrik XLR
Perhaps you could design a new bottom piece that has provision for a bolt-on Binder type connector, such as you're using now, or optionally a Switchcraft XLR (such as http://www.mouser.com/Search/Refine.aspx?Keyword=502-b3m ). That way, if people want a tube mic they can go the Binder route, or opt, in the case of a FET circuit, to use the Switchcraft XLR.
Or you can design two different bottom plates, one for the Binder, and the other with an XLR-size tube that accepts standard Switchcraft or Neutrik XLR-M inserts. Then people could select from a number of XLR insert options, including 7-pin for a tube mic, yet have the convenience of an XLR rather than a screw-on type like the Binder.
I would opt for the XLR version myself, as I want to build a pair of FET circuits in these. As it is, I'll just make a short cable to adapt from the Binder to a standard 3-pin XLR.
JC
