Hi guys,
Still no news on another production run- we are still negotiating with your manufacturers and will send our an email via our Equinox mailing list whenever we have an update.
If you haven't subscribed to the mailing list, you can do so here:
http://eepurl.com/fM6os
As for replacement screws:
Almost all the screws are M2 or M3. The headbasket screws are M3x0.5, oval, phillips, 8mm long
Here is a mcmaster-carr link:
http://www.mcmaster.com/#90258A178
(Part Number 90258A178)
Here is a list of all the screws:
Screws
headbasket screw M3x0.5, oval, phillips, 8mm length
Capsule Riser Set Screw M2x0.4, set screw, 8mm length
capsule disc screw M3x0.5, pan, phillips, 6mm length
side rail screw M3x0.5, flat, slotted, 6mm length
body screw M2x0.4, flat, slotted, 5mm length
