Marcocet
I'm in for 2
ddt said:...and, here's what the panel designs will look like
Dan
dustbro said:Great job dan!
snipsnip said:desaign looks great. whats the colour scheme on your panels?
0dbfs said:I am looking at the 760 options to put together two units. I would really love to go with a 2RU case/panel but can't envision how two of the main PCB's will fit in there. The proto-photo's I have seen in the various threads have all been 1RU and it looks like a tight fit for two main boards.
Also noted that it appears the proto's are powered by an external psu which means even less room in a 2RU unit if looking to go with an internal PSU. Is there a PSU section included on the main PCB or maybe an external board? I'm sure it would be easy enough to adapt an already existing design but I was just wondering.
Slenderchap said:There is a stereo link connector on the rear anyway .... I guess that you could run that through a switch is so desired....
The Bypass is the "System In" switch on the front..... not a true bypass as it always goes through the output amplifier....
