GSSL super sidechain, relay sourcing/defining problem...
finbase
Espoo, Finland
Hello Folks!
I'm just about to place an order for the GSSL kit + super sidechain PCB from Gustav (pcbgrinder.com)... But since I'm living in the most backward country in the EU, I can't use Farnell, so I'm sourcing all the sidechain BOM components from mouser.com (not a bad option, though). Unforunately I just CAN'T find the right relay.
Relays in general seem to be rather confusing: there are a bewildering amount of different types. But it doesn't help a bit that there doesn't seem to be a consistent way of defining them (like i.e. capacitors). Farnell's and Mouser's sourcing filters point out different features and use different terminology, and the actual manufacturers' datasheets do the same...
So here's the relay specs I'd need (according to the BOM on Gustav's website:
24v DPDT Relay, 2800 Coil. Farnell type 9480226
Farnell Link: http://uk.farnell.com/multicomp/hrs2h-s-dc24v/relay-dpdt-2a-24vdc-tht/dp/9480226?Ntt=948-0226
More information on the super sidechain:
https://pcbgrinder.com/download/SSCdocuments.pdf
On mouser.com I've ended up with this one, but since I just can't cope with the relay datasheets, I'm not sure whether I can utilize it in the super sidechain circuitry or not:
http://fi.mouser.com/ProductDetail/TE-Connectivity-Axicom/C93419/?qs=sGAEpiMZZMtSzCF3XBhmWyD9EW7DQbtZFQokC82GuIA%3d
Mouser Part No: 655-C93419
Manufacturer Part No: C93419
Could you please help me out... I'm getting darn frustrated. My wife would definitely be thankful too! ;)
DIYing is wonderful, but I hate relays!
-finbase
OMRON G5V-2-H1 24VDC is a compatible maybe easier to source part.
Thanks Harpo!
I'll go with that one! :)
finbase
