Echo North
envelope said:Echo North said:AL-19/PPM 14 Type VU'
Here is what is in production:
- 1ma/600ohm linearish (the sifam is not perfectly linear either) meter with B style bezel and white needle (SSL Scale)
- Standard VU with B style bezel and Hairball retro VU scale
- Standard VU with WF style bezel and Hairball retro VU scale
Mike
Hello Mike, I am hoping to use one of your new 1mA meters for use with Dan's 2254C case. Have you arrived at a price yet, and would the rear cutout dimensions be the same as the Sifam AL19B? the attached picture is of Dan's case. Thank you.
Price: $25(ish)
It has the same hole size as the 19B (27mm). According to the datasheet 19B has mounting holes on the diagonal, where this meter has them on the horizontal (like Dan's case). It should fit perfect!
You can refer to the cutout diagram here to confirm 100%.
http://hairballaudio.com/docs/meters/8027-B.pdf
Mike
