Echo North said:
Definitely use the dual PS MNATS will send you with the boards. It'll remove the messy redundancy of using to on board power supplies.
Potato, potato
. If I don't mind populating both PCB's PSU's and the small added cost involved - is there an issue with wanting to eliminate the 5th PCB (the PSU PCB) in this build? With the (2) Main PCB's, the TWO Stereo Link PCB's, plus the PSU PCB and 4 Transformers plus Mains Transformer in one chassis - it might start to get crammed ("messy"
) in there - no? Jumping the 3 AC/0/AC wires from one PCB to the other seems cleaner and more space efficient by comparison.
Echo North said:
Both the meter and ratio rotaries I posted above are in stock at mouser. The ratio will allow you to set it up for "slam" mode which Dan has on the front panel. You'll need the dual power supply parts listed here:
http://mnats.net/psu.html
Yes DPDT, though technically I need to design a simple bypass/relay circuit. You could also use an attack pot without a switch and use the "bypass" as a "GR off" instead. Or make your own bypass if you don't want to wait for me.
Mike
So those rotary part numbers you posted above (page 35) are confirmed? I'll add them to my list. Do you have any good suggestions on the GR and Link DPDT switches that will fit in Dan's openings?
I don't really need a hardwired bypass and the associated relays - the GR Disable is all I need.
I did plan on scraping the Attack Pot w/Switch and using Dan's "GR/Bypass" position to connect PAD22 to Ratio Green (or whatever this will be on the rotary version) to enable GR, or connect PAD22 to Ground to "Bypass" with a DPDT (both channels on one switch). So I'll also sub the pushbutton version's Attack pot w/switch with a plain pot of the same value. Good?
Anything else I'm overlooing (aside from not having a case yet
). I guess the mains transformer you included is plenty adequate for 2 channels, the 2 stereo link boards, and 2 meter lamps (probably do the 2W voltage drop resistors on the AC Secondary like you recommend for the Pushbutton models)? Maybe put one meter lamp on each AC secondary to spread the load more evenly?
Thanks so much Mr Mike. 8)
