I have a question about these micro tube mic ?
So I leave it closed there I would like to test the circuit unfortunately the tube is no longer available for purchase 6088 I think it will work Is this circuit even intended for capacitor capsules? the idea is not bad
No, it's a DI-box. But you could study it for inspiration. You need higher input impendance and also a polarization voltage for the capsule.
I'm trying to find a way with TinkerCAD where we can simulate everything. Let's see if we can make 1 out of the 3 switching circuits that runs with large diaphragm capsules. I found this tube and you can also buy it 1AD4 Uf 1.25 Volt / If 0.1 amps
0.1A is 100mA. There's no way you can power that tube with regular phantom power.
Gang,
The 6088,6418 and other tubes like this are directly heated. I use these all the time and have like 2K of the 6418 here. The 6088 draws 20ma at 1.25V and the smaller 6418 draws 10ma on the filament. BUT here is where it becomes tricky. Unlike an indirectly heated cathode, a directly heated bias point is in the center and it also needs to float bias and for these tubes best to use a current source for that. I use a LM317L with a 121 ohm resistor into pin 5 with a capacitor to ground and bias off pin 3 with a pot. The big problem with these tubes is that they are microphonic if mounted wrong. Put them on a 1/2" of foam. Digikey sells 1/2" foam double tape that works great.
So in triode mode the max gain I have ever gotten is 8. In pentode mode you can get up to 30. The Rp is really high either way so I use typically a 0.33ma current source then use an LSK189 as a source follower to drive the signal.
Here's is one of my clean boost pedals using the 6418 or the 6088. Both do triode strapping of pins 1 & 2 together. These tubes get a little funky in pentode mode. I am working on a 500 series DI and tried to use pentode mode and it's not being consistent across a lot of tubes.
  • oct_smd.pdf
What sort of life time do you see on these lowpower subminis?
This depends on a number of things. If you have a good set current source for the filament at the set amount, you don't draw much grid current, which requires good biasing, lowish grid resistor to ground (under 500K best), reasonable plate voltage then they last a real long time. I bet my pedal has been powered up for over a year 24/7 (8760 hours a year). I don't turn off my pedal board often. Most of these tubes made later were good to 5000 or more hours.
