I have a question about these micro tube mic ?
So I leave it closed there I would like to test the circuit unfortunately the tube is no longer available for purchase 6088 I think it will work Is this circuit even intended for capacitor capsules? the idea is not bad
No, it's a DI-box. But you could study it for inspiration. You need higher input impendance and also a polarization voltage for the capsule.
I'm trying to find a way with TinkerCAD where we can simulate everything. Let's see if we can make 1 out of the 3 switching circuits that runs with large diaphragm capsules. I found this tube and you can also buy it 1AD4 Uf 1.25 Volt / If 0.1 amps
0.1A is 100mA. There's no way you can power that tube with regular phantom power.
