benlindell
Hey guys. I finished and hooked up my la-4 and have been wrestling with in all morning. First I had too big of a power transformer on it (20V) but not with a 15V I'm getting power fine until I connect the PSU part to the rest of the board. At first I was getting power that started at a few volts then dropped to nothing. I inspected everything again and found a bridge between the two 15R, basically connecting +18 to -18. Fixed that and was running with out my output transformer or VU. those two resistors both lit up. now with the transformer and VU they still lite up. Any ideas guys? I done all the instructions in the pdf (connecting the ccw pins on the pots, J1 connected to earth) I don't have any extra 15ohm resistors to swap in at the moment, will replacing the burnt ones fix this?
