wmb
[quote author="dripelectronics"]
you might have to do some trouble shooting on that one unit.
this could be a poorly seated tube , to a loose ground etc.
youll have to simplify the chain , so you can make sure it's the
pcb or not.[/quote]
Yeah, I need to just figure out if it's the guitar amp (non la2a related) or one of the two channels with the la2a in line after the pre's. I've been insanely busy with a couple projects and one that is moving between my studio and another. Too much stuff to get done and not enough time to start poking around in the boxes yet.
I think I will set up a project with the all three sources powered up and let it record them during a lunch break. The interval between spikes is about 20-30 minutes so that should be enough to actually catch one and figure out where it's coming from.
Alternatively I could change my metering to hold peaks longer.
Did I mention how great these things sound? The payoff of the experience has been so great that I now want to build all kinds of stuff.
pcb or not.[/quote]
