[quote author="chingon"]I've been putting this project through the paces and noticed that i get quite a bit of hiss from it. Is this normal? Also when i turn it on i can hear the hiss volume slowly ramp up along with a low buzzlike sound and then it stays. Its actually a pretty noisy unit. The buzz sounds like its at the same rate as my cheap alesis monitor power amp so i'm guessing its picking up and amplifying this noise some how. During the build I installed the grids stoppers for safe measure even i'm not sure what its for or what ossilation is.
Another note: When I grounded the 4 pcb points i grounded them all in the same location instead of different areas as indicated in the manual. Could this be a problem?
Has anybody experienced this?[/quote]
the original la2a ground scheme is how it is on the pcb.
the star ground method can work , but with this project
i have found by duplicating the original layout this works
best ,
otherwise i would have just used a solid ground plane on the pcb
to loose the multi ground set up.
i think many revisions ago in my designs and prototypes i did this
only to end up with an expensive noise machine.
you would be amazed at how much the xlr socket pin 1
can effect things.
either ground this to the case next to the socket , like in the manual ,
or ground it to GND#2 on the pcb ,
do not use the pcb pad marked xlr #1.
the 12bh7a seems to cause this ramping noise if its a bad tube or
seated poorly this can happen,
ive noticed this while the unit was on and connected to some speakers,
that pressing it in better ,stopped this .
(dont blow your speakers or fry your self)
if you have the gain dialed hi , it is normal you will have white noise.
try turning your source up higher , and the la2a lower.
this is often understated thing.
hope this helps,
g.
