Igor said:Take the resistor equal to VCA unity gain (in case of 1x2181, it is 20k; in case of 4x2181, it is 5k), and put it
instead VCA between its input and output. You should have unity gain, phase reversed.
If there is a prob here, check sound path. If no prob, something is wrong with control circuit
(control voltage). Impatiently waiting for results. Curiosity!!!)
Igor said:evil: any news? I impatiently waiting about a week. Curiosity, aye!
Yes. Signal in C&B @39.3kHz will be -3dB down. Still -1dB down @20kHz. Not the end of the world. YMMV.baadc0de said:Am I correct this cuts off at 39kHz?
ilfungo said:Mix Buzz finally works! ;D
my problems:
2 x that1246 broken
1 bad soldering
Thanks to all for help
Harpo said:Yes. Signal in C&B @39.3kHz will be -3dB down. Still -1dB down @20kHz. Not the end of the world. YMMV.baadc0de said:Am I correct this cuts off at 39kHz?
