jandoste
Igor said:Hi to all, still overloaded, NEWS:
Got the PCB's with nice silkscreening, almost stuffed, just to check again to be on safety safe side.
Got the details on kit pricing and panels.
More-tomorrow
So
More-tomorrow
I'm very interested in this also... I have "Art of Electronics", but I have no idea where this figure would be in the bookWhat is the name of the Horowitz-Hill book that explains the hard/soft knee?
Ah yes, and another one-at this time, RATIOS!
http://i251.photobucket.com/albums/gg291/diy33609/HOROWITZ_HILL_SSL.jpg
Answered in previous post-does the $200 kit include pcb or does this go on top pricewise?
I recommend to use B grade VCA's from same batch.-can i start with just one 2181A and add 3 more (from farnell/RS/etc)
at a later stage, if I feel it is needed?
I trying to figure out cheap solution, but minimum order is 50 panels.Lastly - are you offering front panels or is this up to the buyer?
I used ones marked 01-281....yes, it is old good 01 family.Igor, can you be more specific? Are these EAO series 01 switches you're talking about?
MS, C&B for MB500 will be offered later. I don't count much orders for this, but willand would like C&B for mixbuss 500
Will there be a full case available for this build where there will be no holes required to do and is exact for the fully expanded model?
If everything soldered correct...yes, you can go with soundcard and multimeter, it takes 20-40 min to setup. I recommend oscillator, scope, good Fluke even for simplest project to be at safe side.How difficult is the calibration process, what tools will you need for calibration?
Support thread+full documentation. Newbies...is my PITA, but basic version is very friendly.Igor, how is the build manual on this like? Is this build, newbie friendly?
Schematics, pcb stuffing guide, support thread. Docs will be posted sooner.What will you supply with it regards to a build manual? Will it just be a schematic, or will you have step by step process?
Yes, it is mixing clean with compressed.That so called blend knob, is that like the API 2500 version of mixing the same signal that's compressed with the original signal?
There will be long post dedicated to this with full explanations why.What exactly do you mean by not GSSL clone? How does this sound compared to a GSSL?
Hairball. Perfect service, good meters.And what about the meters : are they include in the full kit ?
PERHAPS is asking too much (after the C&B and the M/S options) but...
any chance for an optional OUTPUT transformer?
I already working on adding another small PCB with peak/avg crestfactor and timing...
Sorry, MixBuzz1 has only MIX option. Full-featured MS and S&B will be done in 500 format.Igor, M/S would be a must!
US edition:Art of Electronics, the part about op-amps.
I have Russian 2nd edition, it is bit different.
Can post detailed info on request.
basic kit do not include soft thight
canidoit said:Will there be a full case available for this build where there will be no holes required to do and is exact for the fully expanded model?
stereokillah said:this is what i understood:
att and realease could be stepped or potentiometer
