Phrazemaster
Can't give you a definitive list, but I used a real AC701K with Dany's board. All I did was adjust the PSU heater to 3.85V. It was hard to calibrate it but it does sound terrific!
trans4funks1 said:Hi Dany,
I drew a schematic for the D-49c circuit, and would like to know if you think it looks correct. I will make any edits and replace it with a clean copy if you can take some time, look it over and make suggestions.
I am wondering about the styroflex caps; C1 and C6, It seems like those are rated at 630vDC because that is value of the items you can supply.
If someone wanted to use some other type of cap what is the minimum voltage rating for these two positions?
Thank you.
