Ahh - you are a good man Duantro!
Yes it is making more sense between the schematic and build photos.
So just so I have this straight in my head - the circuit is already setup for pad and lowcut - then simply adding a header to the pins at s1b and s1a at the top 2 pins engages the pad and LC in circuit?
With the header on the inside 2 pins its out of circuit and at the top 2 pins its in circuit?
so then what is s1a ? Pad
and then s1b is LC?
Then I ask what is the "pad on" for? ...or I guess its a switch or 2 switches at "pad on"....... or i simply use the pins and headers?
I hope I have that correct
And lastly I am using the cinemag 13101 - can you instruct me on how to wire in this xfrmer
RT - ROT = Red(1)
BR - Braun = Brown(2)
VI - Violett - Purple = Orange (3)
BL - Blau Blue = Yellow (4)
Black is Ground...
Thanks for your wisdom help and guidance.
